Rheostat made a frizzing noise and dash lights stopped working....based upon previous posts tried to bypass rheostat with jumpers.
For a glorious 4 seconds, dash light worked
Removed jumper, replaced blown fuse with correct fuse, resolved to buy new rheostat.....however, now have no rear and side marker lights working when turning on via column switch....front lights work fine....., it just seems that all items on the 2 circuits (G & H) (left and right rear lights, front and rear side marker lights, lights-on indicator) no longer work. They will work when activating the parking light switch on steering column. All fuses seem ok, and I even checked the in-line fuse behind fuse box.
Any thoughts?
