Matt
well its hard to find oils here in Belgium that contain zddp , the + stands for additive i guess (it adds zddp to your oil)pope wrote:Tappy....as long as there are no ingredients in there to make the oil slicker. I dont know if I would add it. I used a 50w motorcycle oil that was GL-1 certified that had a lot of ZDDP in there.
What does the Plus stand for on the bottle.
MSMatt... thats an advanced course that you were reading. I'm giving you the tried and true ingredients.
thx for the efford , castrol only available in 200l barrels , rotella not imported bye shell Belgium valvoline i need to check , mobile delco 1400 is available but cost 6€ l (+-28$ /gallon)kilrwail wrote:Here are three oils with more than 1200 ppm Zinc, which should be available to you.
Brand Weight P ppm Zn ppm API
Castrol GTX 20w50 1157 1422 SM
Rotella 15w40 1278 1555 CI-4
Valvoline Premium Blue 15w40 1314 1838 CI-4
Better to use one of these than an additive.
You're absolutely right. My bad. I think I saw a similar comment in another thread about motor oils, but I was probably just imagining it. Sorry for the confusion.pope wrote:Pete, were talking about tranny oil. The two 40W are a little thin for that. I think you are listing these as engine oils.
Yeah, what is the story on that? I am pondering a tranny oil change on my 81 Spider 2000 and I can't quite figure how it is that I am going to get oil into the thing -- particularly working in a driveway with a couple of jack stands. Is there a favored method?manoa matt wrote:Filling the transmission is another story altogether.
