Engine Swap Questions and Progress (was "Rebirth!")
- fiasco
For those new to this particular story, the background can be found here: http://www.fiatspider.com/f08/viewtopic.php?f=3&t=5043
The old car and new (old) engine are at my house (thanks to Ryan)! With that particular corner turned, I'm leaving the "Disaster" thread behind, and beginning the documentation of the engine swap in this new thread. To start it all off, here are pics of the engine I picked up at Mark's place (Allison Automotive in Upland, CA) today.
I've done a couple of things this afternoon - took off the alternator, the belts, the timing belt shield and the exhaust manifold heat shield. Sprayed it down with Purple Power and sprayed it off with the hose. I know that's not much, but it's a first step, which means I'm one step closer.
Tomorrow I pick up the engine stand at SpiderRey's house, and I'll be off to the races.
-- se
-- se
Steve Eubanks
Re: Rebirth!
That's fantastic Steve. You're on your way to new adventure. Nobody can say our cars are boring!
Sure wish I could be out there to help.
Joel
Joel
Re: Rebirth!
Glad to hear Steve. On a side note how far are you from Huerta Verde Rd? I have an uncle down in Glendora.
Re: Rebirth!
I hope the first thing is to change to a dual outlet exhaust after cleaning. While under the car inspect the cross member for cracks as well as the frame bolt area. I've found those to be very prone to having small hidden cracks you don't normally see. Good luck with the install.
Re: Rebirth!
Just Happy to help!
See you on the 28th, when I can help some more!
-Ryan
-Ryan
- TulsaSpider
Re: Rebirth!
Make sure to clean out the cyclonic trap. Don't use the large rubber gasket LOL! The trap may need a new elbow hose. This stuff is extrememly hard to get to when in the car. I'd put on a new fuel pump as well. I'd think about changing out the head gasket, again just because it's easy when it's out and you don't know the history. I'd probably switch out the old starter if it was in good shape as you don't know the history of this one. I'd also take off the exhaust and remove the exhaust studs and seal them up so you know they won't leak. Purple power and a few brushes and a few hours and you'll be getting there! Keep us updated Steve! I'd love to be in on the action!
Re: Rebirth!
Congrats on reaching the first major milestone. Hearing it start for the first time once the swap is completed will be the most beautiful sound you have ever heard. keep us posted on you progress.
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
'12 Abarth 500
- fiasco
Re: Rebirth!
Don't know what the cyclonic trap is.TulsaSpider wrote:Make sure to clean out the cyclonic trap. Don't use the large rubber gasket LOL! The trap may need a new elbow hose. . . I'd also take off the exhaust and remove the exhaust studs and seal them up so you know they won't leak.
What large rubber gasket?
What do I use to seal the studs?
Starting to make progress. Got a lot off the new engine last night in prep for cleaning - gonna take a bag of parts over to Reyy to sandblast. Work on removing the old engine starts today.
Wise word Ryan!SpiderHead wrote:4th most beautiful.. lol
his wife said yes, and he has two sons
Thanks!
-- se
Steve Eubanks
- fiasco
Can't get the oil drain plug out.
I got the one out of the new engine bu taking hex head bolt that fit in the hex nut and bending it to make a homemade hex wrench. On the old car, I can not get the drain plug to turn. The bolt shaft is twisting as I turn it.
Anyone got any ideas as to how to get the brain plug out of the oil pan? It's holding me up because I want to get all the fluids drained out before I bring it in the garage to start taking parts off.
Been Purple Powering and scrubbing the new engine all morning. Here are some shots of the progress.
Thanks,
-- se
Thanks,
-- se
Steve Eubanks
Re: Engine Swap Questions and Progress (was "Rebirth!")
Hey guys.
What is the cyclonic trap? I have no clue.
the trap is the breather assy under the intake manifold
that looks a lot better then yesterday
- TulsaSpider
It's just above the fuel pump and beneath the intake. It is the crankcase ventilation system. Remove it, clean it thoroughly, you'll need a gasket for it. Inspect the hoses for cracks. There are several posts on the issue.azygoustoyou wrote:Hey guys.
See this-- http://www.fiatspider.com:16080/f08/vie ... a&start=45
Looking good Steve!
- fiasco
Slow progress today, but at least progress. Thanks Reyy for the use of the hex key to get the oil drain plug out.
Got the fluids drained and moved the car into car and up on stands. Took the battery out and the hood off.
Couple of questions:
1. In the Engine removal section, one of my manuals says to remove the radiator first, and the other doesn't. Should I take it out before going further?
2. I've noticed that several of the pieces and parts I've taken off the old engine have gaskets. I don't have replacement gaskets. Should I start making a list and order them as soon as possible so I can be sure they are here by installation day, or can I buy gasket material at Kragen and just make gaskets for these things?
Thanks,
-- se
Thanks,
-- se
Steve Eubanks
