FWIW I did also replace the tensioner bearing when I replace the belt.
I'm sure you realize that you need to tighten the tensioner bracket nuts after the spring is allowed to settle into the 'home' position, . . . right? It's not like the Serpentine belt on a modern car where the tensioner belt is constantly re-tensioning the belt. If the tensioner bolts aren't tightened down, then I could see how something weird could happen -- the worst of which would be the belt slipping a few teeth. I'm guessing you did this correctly, but need to ask anyway.spiderman2000 wrote:Mdrburchette,
. . . The belt is riding on the spring tension of the tensioner. I have added no other force or tension to it. . . .
Good. Sorry, but had to ask and cover all the bases. Now, just to clarify: the tensioner bracket should be flat against the engine block (no washer behind it anywhere), The bearing goes on next -- being sure that it is the correct bearing. Right? The earlier smaller engines had a narrower bearing, which might not support the wider 2.0L belt correcly. Then there is a bearing seat that goes on, with the smaller diameter nestled inside the bearing ID. Then a thick flat washer, a lock washer, and then the big nut.spiderman2000 wrote:. . . loosened the tensioner so that the spring would tightened the belt then tightened all the bolts.
