New Member
Re: New Member
To transfer pictures from photobucket, first resize them to about 1/2 size (edit) so they don't run off the page in your post on the forum. Then click on "IMG code" below the picture you want to post. It should turn yellow and give you a "copied" notification. If not then right click on "IMG code" and then select "copy". All you need to do then is paste it into your message (ctrl+v works). You don't need to use the Img button from those above the message composition area if you do it this way.
Good luck,
Ron
Good luck,
Ron
Re: New Member
Howdy everyone,
A big thanks to Ron for helping me post my pic's. This is my '79 Spider The black and white pic's are at a friends garage where he has a few projects of his own. He was nice enough to let me work on my car there when my pinion gear broke into three pieces. It took me about a year to rebuild the front and rear suspension.
JP
JP
Re: New Member
Pretty ride there JP.
Looks like you're enjoying it too!
Ron
Ron
Re: New Member
But WOW! Look at all the room in it! Looks can be deceiving.
Re: New Member
the pictures are at two different locations. The ones in color are at a movie set before the pinion gear break down..
- TulsaSpider
Re: New Member
JP did you have any symptoms before your rear end gave up?
Re: New Member
Yes I did! It was a gerrgulling noise that stopped when I pushed in the clutch pedal,I thought it was the clutch going out. I was going about 55MPH when it gave way, it was a long day I had to have it towed.
Are you having trouble??
Re: New Member
Ouch! Rear end boo-boo.
Ron
Ron
Re: New Member
Hey JP.
Nice looking ride, and you have a good eye for an interesting background shot. Might wanna consider photography as a second occupation. at the very least, you sure know how to stimulate a conversation.
that pinion gear sure looks chewed up. i betcha it created quite a racket for a while.
welcome to the site.
Re: New Member
Very nice JP.You're going to be amazed at the ride when you get her done. It'll feel like a new car.
Way to go.
Ron
Way to go.
Ron
Re: New Member
Are those Delrin bushings in the control arms? Or is the flash just making them lookin white. If those are Delrin, good luck
Re: New Member
looks nice. A nice set of braided steel brake hoses would finish it off nicely, and improve the braking as well
