New top
New top
I my process of restoration, I have had to have a good look at my top. It is virtually unmarked, however the rear window has faded. I am considering importing a new top. Any supplier recommendations and how hard are they to fit ?
Baz
Baz
- manoa matt
Re: New top
Baz,
There have been a few members that have had luck with polishing compounds to clear up the vinyl window. If its severly chalked but the top is still good some top installers can cut out and re-weld in a new vinyl window. What year is your car?
Re: New top
I have a 1977 Spidy (82 motor) There are no tears in the top, a bit ratty round the rear window areas, but could be fixed. I fear that with the new paint job, attention will be drawn to the rear window.
Re: New top
replacement windows get stitched in rather than heat sealed like the originals. No upholstery shop will attempt a window replacement if the top is ratty, because the installation won't be successful.
Re: New top
Baz,
As manoa matt suggests, try the plastic polishing compound.
When I got my '78 Spider I used it to remove most traces of a large "X" some chit-hed carved in the rear window. I also removed most of the yellowing in a top on another Spider just to see if I could make it last a while longer.
Notice in both cases I said "most". It took a lot of elbow grease to get the tops this far. More work would have made them even better.
If your top is still serviceable and it's just an ugly window, you should give the compound a try -- Autozone, Advance, O'Reilly, maybe Wal-Mart.
Ernie
Ernie
Re: New top
OK...Thanks men..I will give that a try. While I am at it, I have seen some reference to the 'Short Shifter' made in some strings in this forum. Are we talking about a shorter gear stick ? ...yea...of course we are. Any info anywhere ??
Baz
Baz
Re: New top
I also have one. I think it's terrific! The feel of the shifter at this length feels much better than at the original length.
More "sports car" like.
I should mention that I put a nut under mine, it's not required, but I like to rub the flat spot when I shift.
Ron
Ron
Re: New top
That would be just down right dangerous, sorta like trying to pat your head and rub your stomach all at the same time but the consequences of a miscue would be bad and I would hate to see anything happen to a spider.
Re: New top
Uh huh, I shore can.
I would have said that I like to rub the flat spot on the nut, but I thought that might have been cause for comments.
Little did I know.
Ron
Little did I know.
Ron
Re: New top
What the heck are you talking about? I'm lost.rlux4 wrote: I should mention that I put a nut under mine, it's not required, but I like to rub the flat spot when I shift.
Ron
