Double check before I buy stuff
fiasco
Post by fiasco »
I just want to be sure about a couple of things before I place an order.
First: I am getting a timing belt and tensioner for my upcoming timing belt change. Vicks has a "tensioner bearing" (http://www.vickauto.com/cgi-bin/store/02-4346.html) and IAP has a "tensioner" (http://www.international-auto.com/timin ... ioners.cfm).
The one from Vicks looks like just a wheel. The one from IAP looks like a wheel attached to a bracket. Of course the IAP page says that this item is not available for my car ('76 Spider), so maybe the picture is a tensioner for another vehicle, but I just want to be sure that if I order the tensioner bearing from Vicks that I am ordering the right thing.
Second: Mark suggested I replace the air pump belt while I am in there, since it is under the timing cover. Vicks shows a smog pump belt, which I am assuming is the same thing, unless I am wrong, so someone let me know if I am.
Thanks,
-- se
Steve Eubanks
kristoj
Re: Double check before I buy stuff
Post by kristoj »
You need a tensioner bearing. The reason the IAP page says that part is not available for your car is because that part is for Alfa-Romeos. This is the part you need: http://www.international-auto.com/index ... 41&noapp=1.
The smog pump belt and air pump belt are the same thing.
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
fiasco
Post by fiasco »
Thanks John!
-- se
Steve Eubanks
Steve
now that your car has passed the smog check, I'd leave the air pump belt off until the next inspection is due. Your motor is an interference motor and a seized smog pump can cause the timing belt to jump, bending valves.
fiasco
Post by fiasco »
So Cal Mark wrote:Steve
Gotcha. Thanks Mark.
Steve Eubanks
