I have an '83 with around 78,000 miles
What would be a normal pressure at idle?
what would be ideal pressure at lets say 4000-5000rmp?
I have a big leak in my exhaust pipe between the catalytic conventer and the the mid resonator (where it makes a high curve, but havent have the chance to fix it). can this affect this oil gauge readings?
Francisco
Oil pressure question
Re: Oil pressure question
oil pressure at idle with a hot engine will probably be in the 10-15lb range, 30-40 at speed. An exhaust leak will not affect oil pressure, but the fumes could make your eyes blurry and make it hard to see the gauge clearly
yes I need to fix that pipe!!
Well my car reading is 0 when idle and about half way or 55 when in highway, I feel strong acceleration... but that 0 at idle makes me worry!
Im trying to take care of the mechanics before getting it ready for paint.
Thanks Mark
Thanks Mark
you can't always trust the stock electrical gauge, hook up a mechanical gauge to accurately test the pressure
I'd be more concerned if the oil light came on. Like Mark says, the oil pressure gauge is rarely accurate.
yes I just confirmed, started the car again today and the pressure at idle was about 15....I'll get me a mechanical one.
