Interior leak and overheating
- Patron 2024
Well I've replaced the thermostat (the old one had part of the seal stuck out of it kinda figure that means it's bad), and the sensor on the radiator (didn't have one before).
Ya know off topic real quick, a Fiat is not lets grab the duct tape and go to town car, if your mechanically challenged buy a Ford Pinto not a beautiful sports car.
I've got the dash, uppper and lower out, heater cover and am working my way toward the core. I know it's the area of the problem because there is rust and deterioration along with fluid on the right interior of the box cover and fan located within.
Would it help if I loosen the hose mounts in the engine compartment next to the firewall where the hoses go to the core?
Thanks, removed the hoses.
I finally have the core out and I am depressed because what I see does not give me warm and fuzzies! The first one I removed is full of a sandy type mud the second one had little build up but not as bad. The core it self to me looks bad. Covered in debris, rusty, lime build up. I don't think I'm going to get away with just new seals.
What are your opinons?
Received the new heater core and valve with gaskets and picked up new hex nuts @ Ace. Put everything together than I noticed one small issue. The casing that goes around the heater fan is warped (like it reshaped due to heat), so I will get a new one but I want to test the fan motor before putting everything back together. I want to make sure the bent plastic that prevented the fan from turning didn't cause motor damage.
I am looking for information on how to test the heater fan motor!
Can anyone please direct me?
