Prototype Bumper Blocks-another alternative
While our Abarth-style bumper blocks are in the works, I've been experimenting with another style. Here are photos of the prototype. Personally, I think the round style fits better with the theme of the front end; especially with our round light kit. On the green car, I chose to mount them inboard of the old bumper mounts, leaving the light kit in the bumper mount hole. On the blue car, the block covers the original bumper mount hole.
These will be fiberglass blocks, pretty much ornamental to comply with various states' bumper laws. The center hole could accomodate either a reflector or led light, but will come with a plug to fill the hole. Let me know your thoughts
manoa matt
Re: Prototype Bumper Blocks-another alternative
Post by manoa matt »
I think they look pretty good. The simplist solutions are usually the best. On the blue car is there any way to connect that bumperette to the bumper shock mount? Possibly cut off the tangs on the end of the shock, weld a nut on in the center and use a stainless screw with an escushion washer to secure the rubber bumper through that hole to the end of the shock. I guess it would have to stick out further or the hole opened up so if compressed it does not push in the valance. Is that rubber piece solid or does it have a hollowed out backside?
it's not solid but has inside braces to hold the mounting bolt. The shock mounts would need to be modified to use the block on them
mdrburchette
Post by mdrburchette »
I dunno, Mark. They kinda look like...well, I don't know exactly what they look like, but I think I like the original style bumper blocks better. :oops:
they are quite different, but less intrusive than the Abarth style blocks IMHO
mdrburchette
Maybe a picture from a bit farther away with the whole front end of the car would give a better view. It's hard to determine what the overall look would be from close up.
kristoj
Post by kristoj »
mdrburchette wrote:I dunno, Mark. They kinda look like...well, I don't know exactly what they look like, but I think I like the original style bumper blocks better. :oops:
Pervert!
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
danaspider
Your car is a: 1979 Spider 2000 79 vw bus
Post by danaspider »
Mark, thinking on these. Could they be painted or molded in some standard Fiat colors? Then they would be there but not as visible as an add-on.
Then there are pervert thoughts of tassels from the bolt hole.
Luck Dana
79 Spider 2000
carb
It all about the romace of the car and owner
mdrburchette
Oh my Gawd...dirty, dirty boyz! :shock: Would you want those tassles the color of the car?
the blocks will be fiberglass, so they can be painted any color you wish (please, no crackle paint). Tassles would be a good aid to determine air flow at the front of the car. If you can make them spin in opposite directions, you get brownie points and a featured youtube video
manoa matt
"If you can make them spin in opposite directions, you get brownie points and a featured youtube video" well....How about two small electric motors with one wired backwards, or even a modified wiper linkage. I got the motors and an extra linkage, just send me the bumpers and I'll make the video.
danaspider
It would have to be chrome tassells or red white and blue little propellers. Ahhhh remembering the good old days.
Luck Dana
79 Spider 2000
carb
miragesmack
Post by miragesmack »
My $.02...not a fan. But I probably need to see a pic of the whole front end, not just a closeup. I like the Abarth look myslef, but sometimes change takes a while to grow on me.
