Let the painting begin... Abarth.. why not :)
mdrburchette
Re: Let the painting begin... Abarth.. why not :)
Post by mdrburchette »
The early models didn't have the lower grille. I don't know why they added it since I've never had an overheating problem due to air flow.
perthling
Post by perthling »
Yep, the second (lower) grille cut-out was post-74.
_______________________
Perthling
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
http://www.fiatlancia.org.au
since North America was the primary market for the Spider, perhaps they anticipated the addition of AC or realized the need for extra cooling as the engines got larger
Braido
Post by Braido »
Very nice pictures the car looks great! I noticed from the picture of the rear that you had the same problem as me. When i took the bumpers off i had to drop the gas tank after to get the drivers side bumper post off, what a pain!
stefhahn
Post by stefhahn »
Hi -
removing the rear driver side bumper bracket is easier than I thought - after a hint I got in another forum - I did this last spring by removing all the nuts around the tank and then lifting it up w/ my hydraulic jack (plus a rather big piece of wood to distribute the power) until I was able to access the bolt holding it. It will squeeze the big rubber hose a bit but left it intact (with some safety) - it's a 20/30 minutes job, a lot easier than I thought. I recommend to have a nearly empty tank at that point of time.
ciao,
Stefan
joshuagore
Post by joshuagore »
stefhahn wrote:Hi -
ciao,
Stefan
Hmmmm I will try this, unless of course I am low on fuel in which case I will drain it.
Josh
Braido
Post by Braido »
Mine is finished now, here are some photo's:
Braido
Post by Braido »
One more...
Chap
Post by Chap »
Looks fantastic Braido! The turn signals, were they originally the side markers?
Edit: Mia Culpa, I see you posted about this already.
~Steve
mdrburchette
Very nice!
Braido
Post by Braido »
Thanks guys, yes they were the side markers. I thought they looked more correct to the car so we changed them up a bit so they would work as the signal lights.
Thanks again for the comments,
