Are the two main jets the brass ones inside the base of the tank that the float sits in? I see part 13 on an exploded ADFA parts list but it is just floating in space, without context.wetminkey wrote: I believe that the main jet resides behind the power valve housing and diaphragm.
Weber 32 ADFA rebuilding question
- Topless
- Your car is a: 1979 Fiat 124 Spider 2000
Re: Weber 32 ADFA rebuilding question
Try this insteadTopless wrote:This link appears inactive. Any way to renew it?PaulC wrote:As promised a link to my ADHA rebuild write-up:
https://drive.google.com/open?id=1DLaHY ... LPJhnPPROL
https://www.mirafiori.com/forum/viewtopic.php?t=98334
Its for an ADHA but nearly identical to the ADFA.
And yes, the two main jets sit inside the float bowl. The two outside the bowl are the air corrector jets.
