Yes, 850 rpm or thereabouts. It doesn't have to be exact, just low enough that the centrifugal advance inside the distributor hasn't started advancing. As you rev the engine, the timing mark on the crankshaft pulley should move clockwise. If your centrifugal advance is working. If it doesn't move, your centrifugal advance mechanism could be stuck (which would cause the problems that you're seeing).charlielucky wrote: I believe the idling rpm is supposed to be 850rpm. If the timing is off can I rotate the distributor a bit to compensate?
And yes, rotating the distributor is how you change the timing. Rotating counterclockwise (viewed from the top) will advance the timing; rotating clockwise will retard the timing. It doesn't take much. A half-inch movement on the outer circumference of the distributor cap will change the timing by about 20 degrees.
As for removing the old starter? This is one of the more challenging jobs on a spider. Those top two bolts aren't easy. You just have to play with a combination of 13mm sockets, socket extensions, and a swivel joint. Depending on how large your hands are, sometimes you can get a hand up between the bellhousing and transmission tunnel, in order to feel where the bolt is. If you can change a starter motor in a spider, you have reached elite status in your quest!
