Is the flywheel visible without removing engine?
- Topless
- Your car is a: 1979 Fiat 124 Spider 2000
Hearing some weird clanks after a DIY timing service... Not sure what it could be but read that if you try to remove the crank nut using the starter there is risk of knocking a tooth off the flywheel and wonder if that's something I can check visually without deep surgery.
Re: Is the flywheel visible without removing engine?
You can see the bottom part of the flywheel by removing the flywheel cover. Then rotate the engine to see other parts. I think you can just remove the 4 bolts. It's been a while since I did it.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
- Your car is a: Fiat 124 Spider CS2 1979 California
If you're hearing some weird clanks after replacing the timing belt, make sure the auxiliary shaft is timed right. It has a lobe to drive the gas pump, if it's not positioned right, the lobe can hit a connecting rod or something. As the auxiliary shaft turns really easy with the timing belt off, it's easy to mess that app. Don't ask me how I know that...
