When looking at parts some brands show compatibility till 1978 and some brands show compatibility all the way through 82. Are the ignition control modules the same all throughout ? I know its a gm style 4pin ICM. just wanted to clarify if anyone knows if there are differences between years. Mine works fine i just wanted to have a spare in hand.
Standard Ignition Motor Products LX301 shows compatibility till 78
ACDelco Professional D1906 shows compatibility all the years though ~83
Delphi DS10071 Ignition Control Module is another one i was looking at.
Ignition control Module question for a 1981 124
- Your car is a: 1981 Pininfarina
Re: Ignition control Module question for a 1981 124
They didn't start using electronic ignition until 79. And it is a 4-pin GM part. If they show a module before 79, it's bogus.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Thankyou for the response. So they should just work fine all throughout then ? There is no special specs other than the 4pin gm style ? The ICM is just a signal amplifier correct ?bobplyler wrote:They didn't start using electronic ignition until 79. And it is a 4-pin GM part. If they show a module before 79, it's bogus.
