Sorry for asking noob questions but...
Where does this green cable go? below the starterarea.
https://imgur.com/a/LT3jRS8
Green ground? under the car
- Your car is a: 1980 124 Spider
Re: Green ground? under the car
Mmm…I’m surprised you have a running car with that ground not being properly fastened…anyway, the bolt that seems closest to it…the one that seems to be a bit loose…you can see a bit of “air” between the washer and the head bolt.
Thank you.Anbele wrote:Mmm…I’m surprised you have a running car with that ground not being properly fastened…anyway, the bolt that seems closest to it…the one that seems to be a bit loose…you can see a bit of “air” between the washer and the head bolt.
So it is a body to engine ground?
haha the car is not running. Thats why I am here so much
- Patron 2024
Some folks move the ground to one of the starter mounting bolts. They are less likely to strip when tightened and many believe it makes a better grounding point as the starter is the greatest current draw the car has.
Yes. If you think about it, the engine has almost no ground connections to the body. All the hoses are rubber, the engine sits on rubber engine mounts, the transmission output goes through the rubber giubo, and the exhaust is usually mounted with rubber hangers. Nothing conductive between the engine/transmission and body except for that the green cable.johankjellgren wrote:So it is a body to engine ground?
Without that ground cable, the clutch cable is about the only thing that could act as a ground, but even that has plastic bushings on the pedal spindle. Plus, the cable wasn't designed to carry electrical current, so if it does, it can heat up and start causing clutch cable problems.
Thank You, Makes sense. It is now firmly attached to the starter mount.18Fiatsandcounting wrote:Yes. If you think about it, the engine has almost no ground connections to the body. All the hoses are rubber, the engine sits on rubber engine mounts, the transmission output goes through the rubber giubo, and the exhaust is usually mounted with rubber hangers. Nothing conductive between the engine/transmission and body except for that the green cable.johankjellgren wrote:So it is a body to engine ground?
Slowly getting closer to the day I can start the engine.
Try to do something every day
I have an automatic and a 131 tranny (radiator, pedals etc) which would be step 2.
