Overheat fan Howling
F16Waldo
Patron 2024
Patron 2024
Your car is a: 1983 Pininfarina Spider
Post by F16Waldo »
Getting car ready for the summer yesterday and when the overheat fan came on, it was making a huge ruckus.
https://youtube.com/shorts/D2T6PLBM_5c
Question to the crowd is, can this be repaired (e,g, new bearing) or does the whole assembly need to be replaced?
Thanks in advance
Damsels Rescued...Dragons Slain
Re: Overheat fan Howling
It sounds to me like the fan blades are hitting either the shroud or the radiator. Bearing noises are usually a rumbling sound. With the engine off, try spinning the fan blades by hand, including seeing if the blades move towards the radiator or away from it (they shouldn't). What do you feel or hear?
F16Waldo
Patron 2024
Patron 2024
Post by F16Waldo »
18Fiatsandcounting wrote:the fan blades are hitting either the shroud or the radiator.
Good call Bryan! Blades nicking the shroud. Going to replace entire unit with 14" fan.
TX82FIAT
Post by TX82FIAT »
Replacing the fan will work. While you are in there take a close look to make sure something else has not moved or dislodged something creating the contact point. Could be a symptom of something else out of place with the car.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
