Adding Turbo
Scarpa
Your car is a: 1981 SPIDER
Adding Turbo
Post by Scarpa »
Hey is it possible on my '81 CS0 to add a turbo and essentially turn it into CS2 model?
rodo
Your car is a: 1981 Spider
Re: Adding Turbo
Post by rodo »
What is a CS0 and a CS2?
Re: Adding Turbo
CS0, CS1, and CS2 refer to the chassis type for the spiders, but Fiat's system was kinda goofy. CS1 is the 1800 spiders up through 1978, CS2 was the carburetor 2L spiders in 1979 and 1980, and CS0 was the fuel injected spiders from 1980 onward.
I'm not positive what a turbo spider is, in terms of CS number, but the turbo was in 1982 so I guess that would make it a CS0?
rodo
Re: Adding Turbo
Post by rodo »
So what is Scarpa exactly asking, Bryan? I'm not sure I followed his question, why it matters.
Re: Adding Turbo
I don't know for sure, so we'll have to wait for Scarpa to get back to us. My own feeling is that it would be very, very difficult to add a turbo to a fuel injected spider (or any spider). There are far cheaper and more reliable ways of gaining an extra 20 HP (high compression pistons, cams, etc).
Scarpa
Re: Adding Turbo
Post by Scarpa »
Sorry it took so long to reply.
According to this Fiat Spider Wiki, 1981 had a CS0 ( no turbo ) and CS2 ( w/ Turbo ). I have a CS0 per the car's ID plate.
Thanks, Bryan, for the feedback. It's not something I was sure to pursue eventually. It sounds like I shouldn't and should invest in other areas.
rodo
Re: Adding Turbo
Post by rodo »
I agree with Bryan: too much, too hard, not enough payback. But if you are desperate for a turbo spider...find one for sale. They pop up every once in a while. Fun to mess about with. Also a huge headache. Ask me how I know.
ORFORD2004
Re: Adding Turbo
Post by ORFORD2004 »
Add an extra 20 HP Lolllll I suspect that i have 200-250HP with mine. I'll know for shure because i will go to tune it on a dyno in the begining of June.
Nut124
Re: Adding Turbo
Post by Nut124 »
ORFORD2004 wrote:Add an extra 20 HP Lolllll I suspect that i have 200-250HP with mine. I'll know for shure because i will go to tune it on a dyno in the begining of June.
Looking forward to seeing that dyno chart. Do you know how much boost you are running?
I believe the turbos did not come like that from Fiat. They were the brain child of the US importer.
ORFORD2004
Re: Adding Turbo
I was running about 14 PSI before i crack the piston #4 Between the compression ring. We decide to shave .060 from the top of the piston to lower the compression to try to prevent knock. This kit is not from Fiat but homemade.
Nut124
Re: Adding Turbo
Post by Nut124 »
That's quite a bit of boost. Are you running an intercooler?
ORFORD2004
Re: Adding Turbo
Yes
Nut124
Re: Adding Turbo
Post by Nut124 »
Yes
Sounds like you have a very cool project. Have you shared specs, pictures? I'd be interested.
ORFORD2004
Re: Adding Turbo
Picture here is not so funny. I call it my little racing gokart. I now install a 131 transmission in it.
