Clicking sound from engine?
WadiaAbushanab
Your car is a: 1980 Fiat Spider 2000
Post by WadiaAbushanab »
Put a new exhaust system and performance was great. Previously I couldn’t climb past 3k rpm’s but after exhaust I could easily get to 5k. A few weeks later I hear a clicking coming from the engine near the headers and a huge loss of performance, back to stopping at 3k. Replaced the header gasket as I thought it was a leak. Still bad performance and I don’t know what the clicking is.
TX82FIAT
Re: Clicking sound from engine?
Post by TX82FIAT »
use a mechanics stethoscope or a long screwdriver end to ear to try to localize where the clicking is coming from. if it sounds like it is coming from under the exhaust side cam cover, I would check your valve clearances. Hopefully it is jut valve clatter. It is possible the clicking is a burnt valve related to the new exhaust heat.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Nut124
Post by Nut124 »
These engines should happily pull to 6000. If not, then something is not right.
Have you checked ignition timing? Lack of advance results in poor power and can burn an exhaust valve.
