Convertible top question
georgeramos
Your car is a: 1971 124 Spider 1608
Post by georgeramos »
Hi all, is it possible to remove and replace the top frame with the top installed? Im buying a really nice canvas top and the frame is in better shape than mine.
Anbele
Your car is a: 1979 Spider 2000 CS2
Re: Convertible top question
Post by Anbele »
Assuming they are in the same manufacturing years bracket, I don’t see why not. It’s fastened to the car by two Allen type bolts on each side of the braces…don’t forget though to loosen and free the tensioning steel cables first. (You really want a second set of hands though to remove it—and install the new one)
Online
I agree with Anbele, as long as the model years are similar, you should be fine. I vaguely recall that there were some changes in the tops in the later model years that might cause an issue for your '71, but I'm guessing these are fixable. I can't remember the exact cutoff year for the changes, but I think it was late 1970s.
I currently have only one decent top (long story), and I swap this back as forth as needed between my '69 and '71. For those years, everything is the same.
georgeramos
Oh I see, this certainly gives me pause. A quick look at AR's website shows different tops from 79 to 85...
Does anyone know what the changes were and if the swap of an 85 top/frame would suit a 71 (if modified)?
georgeramos
I think I understand this. Based on this reference
https://www.convertibletopguys.com/site ... rtible-top
in 79 there was a design change to the bow. The pre-79 soft tops are not compatible with the later BOW but I would "assume" both styles of bow are compatible with the windshield frame, does this make sense?
So if I swap out the frame with a top pre installed which has the later bow it should fit my 71...
georgeramos
Re: Convertible top question ANSWERED
Yes, the later top bows/tops will suit early cars. The incompatibility is with the soft tops themselves since there are two different shaped bows. This seems super obvious now...
thanks
georgeramos
OK I do have an issue happening Id like to ask about. Is there some sort of spacer that sits between the mounting flange and the body of the car? The new frame sits too close to the outside edges and the triangular windows/surround contact the body trim pieces that sit behind the doors. It seem I neglected to put something back when I re assembled the thing...
Does anyone have a diagram of the top frame and all its associated parts?
Zoofly
Post by Zoofly »
There is a spacer on my 78. Maybe that's what you need for yours.
2020 124 Spider Abarth
2019 Alpha Romeo Stelvio - sold
1977 Triumph Spitfire
2017 Fiat 124 Spider Classica - sold
1999 Jaguar XK8 - sold
1998 BMW Z3 - sold
1988 Pontiac Fiero - sold
georgeramos
Thank you!
