I need the proper torque setting for the banjo bolts on the inlet and outlet lines to the radiator. There are copper crush washers similar to brake lines. Can't find the settings in the shop manual.
Thanks!
Automatic transmission radiator connection banjo bolt torque
- Your car is a: 1981 Fiat Spider 2000 FI Automatic
Current:
'81 Fiat Spider 2000 FI (Purchased Mar 2014)
Previous Italian Motors:
'84 Alfa Romeo GTV6 (Owned '92-'94)
'74 Spider (Owned '87-'89)
'71 Fiat 850 Sport Coupe (Owned '87-'88)
2 '76 Fiat 128 3p's (Owned '83-'87)
'74 128 Sedan (Owned '81-'83)
Re: Automatic transmission radiator connection banjo bolt torque
The torque spec I use for mine is good and thight. I have never looked for an actual number. Always use new washers and try not to break the bolts nor hurt the radiator. So I went out to the shop and looked in my factory repair manual and not a word on the banjo bolts. Good Luck.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
