To 95amp Alternator or not…thoughts
Been reading about it…and not 100% convinced. Current one has no issues.
- geospider
Re: To 95amp Alternator or not…thoughts
Don't wake a sleeping Italian electrical system.
Really, if working well, I wouldn't mess with the alternator. Mine went bad on my '79, replaced with a 65 A and added relays for the lights and the starter. All works great. not sure I would ever run enough to need 95 A. You will get a lot of opinions on this
Geo
Geo
Unless you have added a lot of electrical load you don't need a bigger alternator.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
My Italian grandfather often said "if it ain't broke, don't fix it." So, unless you have issues, I would not buy new parts to replace functioning parts. If lights dim and a few other electrical gremlins do things like clean grounds, clean connections, clean and lube wiper assembly..... and the list goes on. I was having intermittent charging issues back in 2012 and installed the 95 amp alternator. I have also installed a headlight relay and ignition switch relay a few years later. I can tell you the 95 amp alternator was a good replacement for me. But, this was only done for the longevity of the car as I can confidently say I have touched every circuit on the car. I agree with some of the comments. The electrical system needs to be well sorted before increasing the pressure (amps) in a system with too much resistance (Ohms). Old poorly insulated wires can get hot leading to all kinds of new problems. it all starts with clean grounds and connections.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
