Front Turn Signal Options?
simon
Post by simon »
I like the bumper-less look. Was thinking about getting the Abarth type bumpers to replace the old bumpers. I was wondering what my options might be for turn signals that fit the larger square holes next to the holes the bumpers mount in. I saw that Mark has some smaller round lights that fit the bumper holes, but those would limit me from being able to do the smaller bumpers I mentioned before.
* I thought I should include that I have a 1978 spider 1800
Re: Front Turn Signal Options?
many of tried to find a light that fits the large hole without success. That hole isn't exactly square. All of the lights I've seen that are large enough to cover the hole just don't look right. I did have one customer that installed the blocks, filled in the large hole then installed my light kit in that location.
sawmkw
Your car is a: 1982 Pininfarina
Post by sawmkw »
And you can see it in my avitar. I like the look.
Scott
82 Spider Green
82 Spider Plum
82 Safari Ivory
80 Spider Driver Red
77 Spider Red
Hopewell NJ USA
miragesmack
Post by miragesmack »
They also make a headlight with the turn signal inside, at the bottom of headlight.
This guy has them:
http://fluforum.italiancarclub.com/gara ... =68&MID=41
I've seen them elsewhere too. Some have LED blinkers, some don't. Some have plastic lenses. All are fairly expensive.
many of the hot rodders use them, but some of those lights only have a single element bulb so it's either a park light or turn signal. Technically, it may not meet some state requirements for brightness as a turn signal.
miragesmack
I can't find my links, but I researched this item. I found one that had single element bulbs that didn't look that bright, and mixed with te headlight beam somewhat.
I found another that was plenty bright, but was LED which I though weird looking on an old car. Didn't seem to look right. It had a seperate defined compartment for the blinkers. I thought the guy I linked had those, but his pics/info is different than what he had before.
Anyway, still it leaves you with a hole. I was interested in filling the hole myself, but most won't do that.
htchevyii
Post by htchevyii »
Trey
Braido
Post by Braido »
I just had my Fiat painted and took the side markers off and used them as the signal lights. Here is a picture of what i did to my car.
those are single filament bulbs, are you doing without park lamps now?
Braido
Post by Braido »
Changed the wiring and bulbs...
FiatColombia1
Post by FiatColombia1 »
Nice set up! did you filled the holes to make them fit that light?
What color is that? have the code? single stage or base coat/ clear coat? more pics?
Braido
Post by Braido »
Thanks, yes we fabricated them into the holes that were already there, used the welder. I removed the side markers, filled in and removed the emblems, and removed the bumpers. I will get you the paint code, i believe it's close to corvette red we changed it up a little added some more orange. I also bought a spoiler from So Cal Mark who i would highly recommend. I have bought many parts for my Fiat and have many problems with ordering from Canada. So Cal Mark has been by far the BEST to deal with, good honest guy that comes through! Check out his website: http://www.allisonsautomotive.com Here are some more pictures of my car, i still haven't installed the spoiler but will when it comes out of Storage in late March (canada is cold eh):
that spoiler could be used as a snow plow over the winter
Braido
Post by Braido »
So Cal Mark wrote:that spoiler could be used as a snow plow over the winter
My friend you have no idea how much snow we get here do you? LOL I'll have to get some studded tires and chains 1st haha
FiatColombia1
What about this....
I was replacing my oilpan today.... but gave myself several break times
I found some plastic lights that are slightly bigger that the front holes. they hold a bulb similar to the bulb used on the stop turn lights. I was surprised by how they look when placing them behind the holes. I hold it in place for the picture... but I think definitively it can be an cheap option. probably draw an outline of the hole on the lenses and paint the outside black, maybe even the black windshield silicone will hold them in place.... well we'll see. I wanted to show you and hear what you think.
Yes... I know someday I'll get me a real oil drain bucket :lol:
