High Energy Ignition Control Unit. It's this banana:maxm50 wrote:Hey Steiny, what’s this GM “HEICU” and heat sink setup you speak of? Just curious...
https://www.ebay.com/itm/153039645135?c ... OsQAvD_BwE
Same thing that Fiat used, just under a different name and therefore dirt cheap.
Wire it up according to this:
https://lh3.googleusercontent.com/25lGK ... 95-h696-no
The Ground point at the screw is critical!
And connect it to a heatsink. I used something out of an old PC Power Supply Unit I had flying around.
This +1979 Fiat distributor + generic $15 coil is the only ignition a Spider will ever need.
^the alternative is to dish out $280 for a coil and module with a Fiat sticker and a giant, aluminum heatsink. To each their own. https://autoricambi.us/coil-module-and- ... y-1979-85/
