engine
fiat218
engine
Post by fiat218 »
how can you tell if your engine is sitting in the bay straight ? mine is at a twist, so when i line up the transmission crossmember, they do not line up to the studs
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
Re: engine
With the engine mounted on its mounts, I put a small level across the top of the block, before the head was installed. Then I put a level across the crossmember, from underneath (cuz the engine is un the way, doh!), from point to point, far left, far right, and compared the angles. This gives the ROLL angle difference. Car must be on level ground to be fully accurate, i.e. little flex. I found that with new engine mounts, it sits almost perfectly in place. There is a little bit of adjustment room, but not much. If these figures are way out, something is probably bent, crossmember, mounts, etc.
Re: engine
One possibility is that the engine mount brackets are the wrong ones, reversed, or just not angled like they should be. Those are the metal brackets that attach to the bottom of the engine with 4 bolts, and the "foot" on them sits on top of the rubber engine mounts. The brackets should both sweep in the same direction front-to-rear, and they usually sweep rearward like an airplane wing.
Re: engine
+1, it is easy to get that wrong.
tima01864
Patron 2021
Patron 2021
Your car is a: 1983 FIAT Pininafarina Spider 2000
Re: engine
Post by tima01864 »
I had the bracket wrong way, It made aligning to the studs difficult but not impossible. Was much better when I had it in the right orientation. I can not remember what orientation, Long side or short side to drivers side.
I am referring to the transmission brackets, One that holds the pillow block.
Daddio
Patron 2019
Patron 2019
Your car is a: 72 124 Coupe 2L project
Re: engine
Post by Daddio »
Pre-catalyst cars have a notch on the passenger (long) side of that bracket for the exhaust, explaining why it is offset in the first place. :wink:
Jeff Aurand
Portland, OR
'72 124 Sport Coupe
'86 Bertone X "Anna"
'70 Volvo 145 "Edna", since 1989
'87 Maserati Biturbo Spyder 2800i
