New from Belgium
If you just registered, post a brief greeting in here.
Danny1988
Your car is a: 1979 2000 spider
New from Belgium
Post by Danny1988 »
Hello everyone ,
I have recently bought a fiat spider 2000 in the Netherlands, but was imported from california
since i am from Belgium , i need to import this one also .. the car seems to be traveling a lot :)
it is a little bit a bad buy , since i paid quit a lot for , but there is loads of work that needs to be done.
- engine running bad
- rust
- bad painting
- all the rubbers needs to be changed
- electric disaster
- subframe broken ( link between the 2 suspension arms and connection from engine )
- heating not working ( fan broken , heat exchanger broken , .. )
- brakes not working
and a lot of other stuff to do :?
aj81spider
Re: New from Belgium
Post by aj81spider »
Welcome aboard. That's quite a list of things to do. However you've come to the right place for help. I had never worked on cars before and managed to restore a 1974 thanks to the help of this forum.
A.J.
2006 Corvette
scrapironchef
Your car is a: 79 Spider
Post by scrapironchef »
Welcome, it looks like you've done a pretty good evaluation of your car and have quite a bit to do. The good news is that most of the mechanical work is well within the skills of the home mechanic.
My advice to you is to read up on what you want to do here and on the mirafiori.com forums, almost everything you are going to do has been done by someone else before and written up. Mirafiori also has all the manuals and microfilms you'll need. There's also a series on youtube from some one who has taken a spider to pieces and put it back together.
pwilliam
Your car is a: 1972 124 Sport Spider
Post by pwilliam »
Could you share the link for the youtube account or videos. Im not anywhere near taking my car apart but am curious to watch the series.
Thanks,
Pete
tima01864
Patron 2021
Patron 2021
Your car is a: 1983 FIAT Pininafarina Spider 2000
Post by tima01864 »
This may bewhat you are searching for https://www.youtube.com/c/ELDESTBuilds/videos
rdv
Your car is a: 69 AS Spider
Post by rdv »
Hi
and welcome too! Hope, you get all problems solved and all work done! This is the right place for all your themes.
Would be great to get your car data for the Worldwide Spider Register! Just fill out the formsheet at our site!
b.t.w.: Quite a lot of cars in Belgium, actually more than 260 cars listed.
Good luck.
Bye, Ralf
(admin of Spider Register)
https://www.fiatspider.de/worldwide-spider-register
mailto:fahrzeugregister@fiatspider.de
69 AS Spider
Be part of it and register your car(s). Starting point here:
scrapironchef
tima01864 wrote:This may bewhat you are searching for https://www.youtube.com/c/ELDESTBuilds/videos
That's the one, be advised that some of the things he does to put things back together can be outside the mainstream and may not be the way you'll want to do things. I also suspect he owns a socket head cap screw factory.
tima01864
Patron 2021
Patron 2021
Post by tima01864 »
Entertaining but I think this is his first go at these cars. Nothing written in stone, Get a second opinion.
geert
Your car is a: 1977 1800spider
Post by geert »
Hello,
just seen this post, from september.
welcome,
I am in the neighbourghood, living in Damme, Belgium.
owning with great pleasure a 1977 1800 spider ( californian) since 1997.
If i can help, with pleasure !.
geert.verdonckt-devriendt@telenet.be
greetings , Geert.
Nut124
Post by Nut124 »
Danny1988, the car does not look too bad.
What is wrong with the subframe? The crossmember is not usually the problem but sometimes there are cracks in the sheet metal body rails in which the sub frame bolts onto. Inspect carefully there and repair as needed for safety. I have seen cracks in the sheet metal frame rails at the top of the front coil spring as well.
Good luck with your project.
