Request: High res images of 2000 FI engine bay
nicktheviking
Post by nicktheviking »
I'm beginning to discover things slightly out of place in my engine bay. I think that the car had a very creative mechanic at one point in its history. There seem to be some custom hoses and things are zip-tied or routed strangely.
Can someone post a relatively stock 2000 FI engine bay so I can compare?
kristoj
Re: Request: High res images of 2000 FI engine bay
Post by kristoj »
There are a bunch of them in another string going on right now http://www.fiatspider.com/f08/viewtopic.php?f=15&t=4247
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
htchevyii
Post by htchevyii »
before
after
Trey
ga.spyder
Post by ga.spyder »
Hey Nick ,
check that link that John(in ''cosmetics'') gave you and if there is something you need little closer or in greater detail ,just let me know.I started that post ,and mine is the first pic.It is stock except for the air filter/cold air .
Craig
Craig Nelson
Fling It Around Turns !
nicktheviking
I think I'm missing the pre-heater valve. :shock:
rlux4
Post by rlux4 »
Nick, what are you calling the pre-heater valve? Where is it located? Or, in you case, where is it missing from?
Ron
Ron Luxmore
rlux2n2@gmail.com
nicktheviking
I have a Cali spider, I don't know if that's why.
The pre-heater valve is the little guy that goes on top of the throttle body inlet.
ga.spyder
Post by ga.spyder »
They call it a 'throttle plate heater' ,should be the same on all f.i. models.Is that picture enough detail ,or do you need something more close up?
Craig
Craig Nelson
nicktheviking
ga.spyder wrote:They call it a 'throttle plate heater' ,should be the same on all f.i. models.Is that picture enough detail ,or do you need something more close up?
Craig
No, I'm positive I don't have one.
htchevyii
Post by htchevyii »
Some of the early f.i. cars had a seperate heater that wrapped around the t.b. and was secured by a spring. The later ones were built in to the plenum. As long as your car runs ok when cold, you might be better off without it, (cooler intake charge). Lenny @ Auto Italia had one listed on Ebay a while back, but his store says he's on vacation until 10-13.
Trey
it does improve cold driveability a little bit, not too much of a factor here in so cal. Hot engine perf would be better without it
kristoj
Post by kristoj »
Nick,
If you are still looking for a throttle plate heater, there is one on e-bay: http://cgi.ebay.com/ebaymotors/FIAT-124 ... QQtcZphoto
John
'12 Abarth 500
pope
Post by pope »
John, that is for the newer F.I. models that have it built in. The one Nick needs is self contained and held on with a clamp and two bolts
kristoj
Post by kristoj »
My bad. I didn't realize there were two versions. I have an '82 and this one fits my car.
John
'12 Abarth 500
nicktheviking
Thanks, but I'm going to run without one. 30 Fahrenheit is about the coldest it gets in Santa Barbara, ever.
