Injector hose repair kit?
nicktheviking
Post by nicktheviking »
Has anyone purchased the injector hose repair kit from IAP?
http://www.international-auto.com/index ... 57&noapp=1
Apparently it's generic, not vehicle-specific and I was wondering if it'll work.
Re: Injector hose repair kit?
it should work, but it's a bit expensive for what you get. Unless you want those original collors, just buy bullk hose and band clamps. You'll save some money
nicktheviking
Good point.
Is 3/8" close enough to 7.5mm or should I order the (more expensive) 7.5mm from IAP?
3/8 is too large, 5/16 is closer
htchevyii
Post by htchevyii »
I bought the kits, but returned them. I used their bulk hose and reused the old hats. They were a bit tricky to remove without bending, I ended up cutting the old hoses with an exacto knife.
Trey
