Thanks for the add to the forum. I have a barn find it’s pretty hammered that more I look at it. I have dreamed of a classic convertible since I was a teen. I look forward to the help, inspiration, and insight I will get from everyone on here. From what I have been told about the car it was in a front end accident that they had to replace the motor hood and fenders at 60kish the car was last road worthy in 94’... The guy I bought it from lost interest after doing a new fuel tank, pump and lines, newer radiator and hoses, cleaned ground post, a used working carb and some other things. I just started working on it this morning draining the oil and getting the car at a good working level on jack stands.
Stuff I will need to assess before starting is finish the coolent line, fuel lines, vaccum lines, oil change, spark plugs, remove the smog crap... California garbage, and new timing belt. I think that should get me started before getting to the rear end leak, brakes and bushings.
Any advice is welcome. I'm located in sonora California
