This is puzzling Tachometer
Gotta love that wiring . . .
sigkadetm
Your car is a: 1980 Fiat spider 2000
Post by sigkadetm »
My tachometer bounces while driving but when I turn on the headlight it returns to normal. Any thoughts????
TX82FIAT
Re: This is puzzling Tachometer
Post by TX82FIAT »
Yes, please read article below about capacitor fix.
https://www.mirafiori.com/faq/content/t ... achfix.htm
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
sigkadetm
Post by sigkadetm »
I have one that says 684J400V will that work?
TX82FIAT
Post by TX82FIAT »
Not familiar with the number and would encourage some research. if it is a 0.68uF 400V capacitor added in series between the negative side of the coil and the electronic tach is should work.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
sigkadetm wrote:I have one that says 684J400V will that work?
Yes, that's it exactly. In the short form for capacitor notation, the first 3 digits relate to the capacitance in picoFarads. One microFarad is 1 million picoFarads. The first two numbers are the value in picoFarads, and the third digit is the multiplier, in this case 10 to the 4th power.
I know that's complicated, but your capacitor is 68 times 10 to the fourth power, or 680,000 picoFarads. Or, 0.68 microFarads.
The letter "J" is the tolerance, and in this case it's plus or minus 5%. 400V means what it sounds like: 400 volts.
Be sure not to use an electrolytic capacitor, which have defined plus and minus terminals. Electrolytics usually come in much higher values like 10 microFarads and above, so chances are very low that your cap is an electrolytic. If it doesn't show a "+" or "-" designation, it's not an electrolytic.
More than you wanted to know, I'm sure! 8)
sigkadetm
Post by sigkadetm »
thanks for the info........it is working
