Turbo kit for 1981 2000
- Your car is a: 1981 Turbo Spider
- joelittel
Re: Turbo kit for 1981 2000
As it turns out, this particular document was already in the Mirafiori library, listed anther CSO Turbo I believe.
- Your car is a: 1981 Fiat 124 spider 2000 turbo
Hi guys,
I have bought a "project" 1981 Fiat Spider Turbo that I am going to restore with my son to the original specs or as close as possible. I know that the parts for the turbocharger are almost impossible to find, but you never know.
What I have left from the turbo system is the Turbo intake plenum, oil pan with oil return, u shaped manifold between turbocharger and exhaust downpipe.
I am missing: exhaust manifold, turbocharger, boost enrichment switches. So by any chance does anyone has the missing parts and is willing to sell them?
When I have had lived in Canada I owned 2 Fiat Spiders , one 1800 carbureted and one 2000 FI. I have moved to Europe and I bought this car as a project to work on with my son as I had great fun with the two cars I have in Canada.
Parts here in Europe are no problem except for the turbo, what is available is only the volumex/turbo head gasket. I have already found VDO enrichment booster switches that match the specifications ( and are adjustable) from the documentation available at mirafiori.com, so it needs only soldering the correct resistors.
I am pulling the engine out of the car this weekend for close inspection and probably rebuild.
I will document the progress and post any information that can be useful to keep as many Turbo Spiders running.
Ludek
Ludek
- Your car is a: 69 AS Spider
Hi
and welcome! Great father&son project, especially to rebuild a Turbo Spider to original condition! Turbo parts are rare indeed!
The worldwide Spider Register actually counts approx. 300 Turbo Spider worldwide. Is your car already listed?
https://www.fiatspider.de/register?Fahr ... ective=All
If not, it would be great to get the car data. Thanks in advance.
Good luck with your project and your parts search!
Cheers Ralf
Cheers Ralf
69 AS Spider
the Worldwide Spider Register
Be part of it and register your car(s). Starting point here:
https://www.fiatspider.de/worldwide-spider-register
Hi Ralf, thanks for the info on Fiat Spider Turbo registry, we will check if the car is already registered by previous owner and if not we will gladly add it.
Ludek
Ludek
We have found that the our car is already in the database https://www.fiatspider.de/register/vehicle/2559
Ludek
Ludek
- Your car is a: 1981 Spider
A few (quite possibly useless) things to add:
Rod, user name rodo, has successfully used switches from presair in case yours don't work out.
A member named hamstra has used, I believe, a Garrett turbo as a replacement (in case you give up on finding an original).
A reputable hydraulics shop can build you an oil supply line in case you need that as well.
Make sure your distributor has one of the centrifugal weights impeded by a metal link, as that prevents over-advancing the timing under load.
At a car show two years ago in CA, I remember an owner saying they had a back-up turbo--so they are out there somewhere!
A PO of my father's '81 had the turbo rebuilt in AZ somewhere, if I remember I will look in the paperwork next time I go out to visit.
Hi
in addition: user Hamstra is Alfred Hamstra from Groningen (NL) a well known Fiat owner and expert (he owned various cars incl. Volumex No.001/500).
Your Turbo car data will be updated in the Register. Upload to next month as always.
Cheers
Cheers
69 AS Spider
Thanx for the info. I have already sent an email to Alfred about the specs of the Garrett turbo he used as a replacement. As for the switches I did some research and VDO has air pressure switches that meet the required specifications with 3 terminals NO/NC that can be modified by adding (soldering) resistors to them : 1750 ohms to 1PSI switch (VDO part No. 430.101)and 500 ohms to 5 PSI switch (VDO 430.104). The switches are also adjustable for boost fine tuning. I just have to find a supplier that has them in stock. I will post my progress.
Ludek
Ludek
Hi guys, I just found out that I have by mistake posted the wrong link to the Fiat Spider Turbo that we have. Here is the correct link to the registry. https://www.fiatspider.de/register/vehicle/2724
I am sorry. Ludek
I am sorry. Ludek
Hi Ludek,
not your mistake, that's one of the "mistakes" of the actual Register. Every month your car will get a new link, so nothing static.
Static will be this result list for a search of just your car:
But.. we are working on a better decision! Cheers
69 AS Spider
