differential drain plug
grasshopper
Your car is a: 1976 Fiat Spider
Post by grasshopper »
Wondering if a universal drain plug can be used on Spider differential ? What type of thread is it ? I can not remove mine. Threads are ok but slots for wrench are rounded off. Thanks.
Re: differential drain plug
A universal drain plug might work, but the threads would have to be metric. How about a new one for Fiats:
https://autoricambi.us/magnetic-oil-drain-plug/
As far as getting the old one out, try vise grips or a pipe wrench. You'll definitely need a new plug after that abuse...
grasshopper
That's a great option thanks. Problem for me is i live in Canada. Shipping charges for one little part is quite expensive. I will have to wait until i need a bunch of parts i guess.
davidbruce
Post by davidbruce »
According to AR''s description of their non magnetic plug. The threads are the same for trans and diff drain and fill plugs. Pull a fill plug and take it to a shop that specializes in hydraulic fittings. There's a good chance they can supply a plug to fit.
Dave Kelly
Campbell River B.C.
1973 Sport(sold)
1980 Spider 2000(project, aren't they all)
ORFORD2004
Post by ORFORD2004 »
Kennyupull Montreal have a 79 in the yard
Nanonevol
Your car is a: 1977 Fiat 124 Spider
Post by Nanonevol »
I could not get mine off either so I put a piece of hose in and siphoned it! It took a long time with the thick oil but enough came out that I was satisfied and did the refill.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
spider2081
Patron 2024
Patron 2024
Post by spider2081 »
First: the end of Allen wrenches often gets slightly rounded from use. To remove worn plugs grind the end of the Allen off until there is no sign of any wear. Then apply valve grinding compound to the outer surface of the Allen wrench for additional gripping. Then tap the wrench into the plug well with a hammer.
I think the oil pan drain is 12 mm That is 0.46875 inch A SAE 1/2 inch Allen wrench would be 0.03125 larger and might fit into a worn 12 mm opening.
I like using using Allen wrenches designed for use with ratchets or breaker bars for drain plugs. For me it is easier to keep direct pressure into the plug and the longer tool handle gives better leverage.
I like pipe wrenches better than vice grips for an alternative tool. The smallest one I have is about 6 inches long. I use it to help remove difficult studs. Double nut the stud, put pipe wrench on the un-threaded portion use correct wrench for the nut and the pipe wrench at same time. This greatly reduces pipe wrench damage to stud.
DieselSpider
Post by DieselSpider »
The differential on my 78 has a plug with a hex end sticking out of it so no Allen wrench involved there. Always use the correct size 6 point socket and there should be no issues with it rounding off. If it has a square end then get the correct square socket and never have problems with it rounding. Using the correct tools for the job will ensure longer life and fewer problems with drain plugs and bolts that need to be removed/adjusted regularly for servicing.
I rarely use a 12 point socket any longer.
Where someone else has already messed things up a ViseGrip Locking Wrench does a better job than the ViseGrip Pliers and even work well on flair nuts.
spider2081
Patron 2024
Patron 2024
Boy are my reading skills poor. "Differential" never registered in my mind. Thank you DieselSpider for your post.
