I want to understand how my carb works because I have stuttering in acceleration when I press the gas pedal about 2/3. I have done a lot of reading (also in this great forum) but now I am stuck.
When I press the pedal for 1/3 I have no troubles and when I hit full throttle I also have no troubles. Stuttering only occurs at 2/3 of gas pedal way.
Here are the facts about my car:
1978 CS1 1756ccm, probably California car now in Austria
Motor number: 132A1.03.6 (I found out it is a California motor)
Head number: 134AS.6C
Carb: 34 DMTR 51/250 8J
I have a few hoses dangling around which are blocked/closed with a screw. I think they are left from the original carb or the smog stuff, I want to find out with your help. Maybe there is an issue.
These two hoses coming out of the intake manifold, 1 is connected to the barrel 1 of the carb, and the second one is blocked. In the carb barrel 2 is also a blocked hose – should they two be connected? I don´t want to try things I don´t understand.
What are these hoses on the intake manifold?
The red one is blocked. And also the green one. From the blue one is only one side blocked.
Can you explain this to me?
I want to block the holes professionally.
Do you have any idea how I can adjust my carb to work correct?
Thanks in advance,
Johannes
