Lift Points
- neoknight88
Lift Points
Does anyone have a diagram showing the lift points for jacking the car up? Normally I'd jack from the bottom of the pumpkin in the rear, but that's where the drain plug for the diff is, and lifting the front is a major pain.
- Odoyle
Re: Lift Points
No diagram but I can tell you, lift the front end with a floor jack under the front crossmember. Place jack stands on front crossmember. Lift the rear with the floor jack on the differential, with the flat spot of the jack behind the face of the diff on the drain plug area. You will have to lift the front end first before lifting the rear.
- Patron 2021
Re: Lift Points
If you can, Drill a hole in a hockey puck to clear the drain plug on the diffrential.
- aj81spider
Re: Lift Points
+1 on both the cross-member in the front and the hockey puck (or piece of wood) in the back on the pumpkin.
However to answer your question - there are four jack points just behind the front wheels and just in front of the back wheels. If you get down and look there are some cross pieces (two) on each that engage the Fiat jack. I don't have a picture, but it is pretty easy to see.
A.J.
2006 Corvette
2006 Corvette
