Pics of timing below, looks dead on!18Fiatsandcounting wrote:I doubt that the cam timing being off by one tooth would cause your problem, either exhaust or intake cams or both. In fact, in my younger (more foolish) days, I played with the cam timing one tooth in either direction to see if I could extract any more performance out of 1438 cc. Short answer: No.
If your timing belt has even a little bit of play in it, you could be off by 1/8" or so on the cam timing marks. With the cam timing marks lined up and transmission in neutral, see if you can rotate the crankshaft at all by hand. If so, you may need to release the lockdown nuts on the timing belt tensioner pulley and make sure it's pulling the belt taut. Retighten after correcting, of course.
If a lot of hoses have been removed or capped off in the intake system, that could be affecting your air/fuel mixture which could lead to some issues. Let us know through pictures or descriptions what you have going on here.
Also I only have one port on the carb blocked off, see picture below too. All other ports on intake manifold and head blocked off.
Going to check if gas is pouring into carb tomorrow.. I can confirm it’s not the throttle cable holding it open.
