Can I use a Fram ph 16 oil filter on my Fiat Spider ? I could not find Fram ph 43 that I usually use.
Thanks for any info,,
oil filter
- Your car is a: 1976 Fiat Spider
Re: oil filter
I don't think so. While an oil filter might appear to "spin on OK", that doesn't mean it's right for the application. I couldn't find anything online that would suggest that a PH16 is OK for a '76 Fiat spider. Might fit, but probably not OK.
Back when Fram PH7 filters were readily available, I used those. Thick 'n' meaty in terms of size, but not so common anymore (or ridiculously expensive). It looks like Fram still recommends this for your '76, if you can find them. Personally, I'd just go with any oil filter that is specified for a '76 Fiat spider, and not lose any sleep over it.
Re: oil filter
Thanks for the reply. I will not use the ph16.
- Your car is a: 1975 Fiat 124
Re: oil filter
If I were you I would take a look at some of the reviews on oil filters on YouTube. All of the testers agree that the Fram filter
is crap. I know I'm going to get flak but that's OK
SAMAKIJOE
AKA GRANDPA GRUMPYPANTS
Re: oil filter
A forum member did an extensive test on many brands, taking them apart, etc, a lot of good work! Bravo. The results were posted here a year or so back (might be longer.... ) Well worth reviewing. The K&N came out very high, that is what many of us use.
- Your car is a: 1981 124 Spider
Re: oil filter
I use Wix 51189 or NAPA Gold 1189 which is the same Wix branded for NAPA.
Steve Muzzillo
1981 124 Spider 2000 (ex-turbo)
2006 Acura MDX
2008 Honda CRV
2014 GMC Acadia
2017 Acura RDX
2006 Acura MDX
2008 Honda CRV
2014 GMC Acadia
2017 Acura RDX
Re: oil filter
A member of this forum (baltobernie) did a comparison of various oil filters several years ago:
http://dcfiats.org/tech/tech.html
(Click on the top link on this page)
I've never had a problem with any of the oil filters I've used over the years, at least a problem that could be traced to the oil filter. However, your mileage may vary, and I'd certainly pay more attention to oil filters for engines that see a lot of hard use (racing, lots of stop and go traffic, temperature extremes, etc.).
Re: oil filter
Thanks for the shout-out. I did this comparison out of curiosity more than anything. I still avoid those brands that appeared to be of lower quality than others, but at a couple of thousand miles per year/filter, probably anything that fits is good enough. Same with motor oil. Correct viscosity and level, change once per season, go on down the road.
- MikeHynes
Re: oil filter
Don't use Fram, they are junk. Of course not many folks cut their filters open, so not many folks see the difference between filter brands. There are huge differences between filter brands. Two brands that appear to be very similar (and highly recommended) are K&N, and Mobile 1. I do cut every oil filter I use open and the only difference I see between K&N and Mobile 1 is the can itself. I think K&N uses a thicker can with that extra "nut" on the bottom. The Mobile 1 filter is usually cheaper of the two, so that's what I use.18Fiatsandcounting wrote:I don't think so. While an oil filter might appear to "spin on OK", that doesn't mean it's right for the application. I couldn't find anything online that would suggest that a PH16 is OK for a '76 Fiat spider. Might fit, but probably not OK.
Re: oil filter
Good to know Mike, thanks. In my case, as my Fiats get driven only occasionally (less than 500 miles per year) and are stored in a garage year-round, I doubt that I'm really stressing my oil filters...! But, I'm glad some people have looked into these matters and found differences that they can share with the group.
- Your car is a: 124 Spider
Re: oil filter
Several years ago a friend and I bought a large number of Fram PH7 off Ebay.
After all the talk about them being junk I am squeamish about using them. But as mentioned above, I don't really stress my car much so I will use up the Frams and switch to the other recommendations then.
Thanks for the great info.
Re: oil filter
I have driven cars to 200,000 to 300,000 miles using fram filters and Walmart oil without a problem. I did this for 20 years without a problem. I run my vehicles hard and maintain well . With the cost of filters and oil verses repairs run what makes you comfortable. I only used the higher end Fram. I now use NAPA gold filters, which are the same as Wicks, I buy them on the yearly sale for half price, which makes them cheaper than the Fram filters.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
