Long story short, I did a brake overhaul this weekend and when I was underneath doing the final checks to make sure everything was bolted up correctly, I realized that the brake compensator rod IS MISSING.
This left me scratching my head, because a week prior, I had the spider up on a lift at my local tire place. They jacked the rear axle up and were able to bleed the rear right caliper (the left caliper's bleeder screw snapped off, one of the reasons I overhauled my brakes). So I can only assume I had the rod at that time.
From the diagram, it does not look like the compensator rod can fall out. The rubber hangers supporting it are complete, no holes or rips or anything. It definitely did not come out when I was working.
Any theories?
The hardy boys and the case of the missing compensator rod
Re: The hardy boys and the case of the missing compensator rod
I've got one if you need it, from a '76.
It's hard to imagine the rod falling out (sorry, I can't look at your picture while here at work -- we have a firewall that prevents it), being that it is fastened on both ends.
Alvon
Alvon
Well, I am an idiot. I checked, and sure enough, it's there, albeit covered in grime.
I guess this case is solved!
- ga.spyder
I bet Nancy Drew somehow got into your garage and replaced it!
Craig
Craig
Craig Nelson
Fling It Around Turns !
I'm thinking Waldo had it with him and happened to come back to town
if it had been painted with Crackle Paint, you would not have had that problem. Trust me, everything I've Crackle Painted can readily be seen all the way from California to Michigan!!
- Tappy
Mike Bouse
Home of the Michigan CRACKLE PAINTER
1978 Fiat Spider "CRCKL"
1980 Fiat Spider "Crackle Queenie"
1969 Triumph Spitfire - for sale (no crackel paint)
Coldwater, Michigan
FLU Board Member
WEST MICHIGAN FLU Chapter Paint/Crackle
Coldwater, Michigan
FLU Board Member
I thought it was a warning
whichever is alright with me
