I rebuilt my engine, its been started maybe 3 times for a total of 5 minutes or so. The sound is a metal scraping sound or something similar. Like a light grinding maybe. It seems to be more on the exhaust side. I checked the timing belt and it's good. The oil pressure is zero on the gauge but I think its the sending unit. I pulled it and it was failing resistance tests. I couldn't get the manual oil pressure testing unit in the small space so I haven't tested the engine that way quite yet. It sounds like it could be a lack of oil but I checked the cam boxes and oil is in there. So I know it's being pumped up. It could be low pressure but I figured maybe someone with a good ear could help figure it out.
Here is a link to the video with sound: https://imgur.com/gallery/ghqT8XP
Is this engine sound normal?
- Your car is a: 69 124
- Your car is a: 1975 Fiat 124
Re: Is this engine sound normal?
I don't know about your motor but I had to take a couple sea sick pills after looking at your video.
After I recover I'll try to look at it again but I'm not making any promises.
OH, and your radiator over flow tank is over filled.
SAMAKIJOE
AKA GRANDPA GRUMPYPANTS
Thanks for the pro tips grandpa grumpypants. The flowtank is lower than the top of the radiator so when trying to get the air bubbles out I sometimes Put put too much in. It happens.samakijoe wrote:I don't know about your motor but I had to take a couple sea sick pills after looking at your video.
grandpa grumpypants here: I really love the new handle.
Thanks.
If your having trouble getting the air out, order up one of these. Works great.
http://www.vickauto.com/newstore/index. ... ts_id=1959
Joe D. AKA grandpa grumpypants
SAMAKIJOE
Absolutly not !samakijoe wrote:Is this engine sound normal?.
But the noice seems coming more from the outside of the engine than the engine itself. Something is not correctly screwed ...
Fiat 124 Spider 1.8L 1978
Jaguar XKR 4.2L 2009
Harley Davidson Fat Bob 96Ci 2011
water pump?
tensioner bearing?
alternator bearing?
a mechanic's stethoscope from HF or elsewhere is a good tool to track this stuff down.
tensioner bearing?
alternator bearing?
- Patron 2019
Have you checked your valve clearances/shims?
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
- Your car is a: 1979 Pininfarina 2000
You are questioning that slight metallic sound in the background? To me it sounds like the thin metal plate between the engine block and the transmission is rubbing against the flywheel. Maybe it got bent when you installed it.
