Noisy fuel pump?
- Your car is a: 1980 Fiat Spider
Noisy fuel pump?
Continuing to sort out issues on my father's '80 Spider... We just got the car running, but from the intake side of the motor we are hearing a pretty significant sound that sounds like an exhaust leak. Can't seem to find a vacuum leak anywhere, but it sounds like it is coming from the the area where the fuel pump is. I have never owned one of these before... Is it possible what we are hearing is chatter from the mechanical fuel pump?
- spidernut
Re: Noisy fuel pump?
Yes. Fuel pumps are cheap too.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
just an FYI, my brand new one is noisy too. I replaced the old one because of noise, so now I have a spare.
- spidernut
That's odd. I've owned five Spiders and the mechanical pumps have never made any noticeable noise.
John G.
I have to agree with spidernut. I've never heard a mechanical fuel pump make noise,...unless it was coming apart!
Electric fuel pumps make a chattering noise,...but that doesn't sound like the problem, due to the location.
Best of luck. Todd.
Best of luck. Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Mine is electric
- Your car is a: Fiat 124 Spider CS2 1979 California
Are you sure your auxiliary shaft is timed correctly? If that's not the case, the lobe that drives the fuel pump can hit other parts, and that will make some substantial noise...
- spidernut
RRoller123 - the fluttering noise of an electric fuel pump is normal.
John G.
I'm assuming yes, but I will dig in with Dad and double-check. Thanks for the reply!gschwab wrote:Are you sure your auxiliary shaft is timed correctly? If that's not the case, the lobe that drives the fuel pump can hit other parts, and that will make some substantial noise...
