I have a lovely new diaphragm from AR (part #FU2-480), but only just THAT. No hardware at all,...
It seems that my old diaphragm is held in place by small hardware that I believe is riveted. Does anyone know how to remove the old diaphragm and install the new one, using the existing hardware?
Pics:
Todd.
Carburetor Secondary Actuating Diaphragm?
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Re: Carburetor Secondary Actuating Diaphragm?
Look around page 7 of my write-up and you'll see four screws holding the top on. If your's are indeed rivets that ain't kosher unless this was a PO change or a later factory change.
Number on mine is 28/32 ADHA 3/79 8H
You misunderstand,...sorry.
I've got the unit opened just fine (screws), and my old diaphragm/shaft disassembled properly.
What you see in the photo is the new diaphragm from AutoRicambi on the left, and my old diaphragm on the right,...Yes, I KNOW it does not look like it need to be replaced! I purchase all rebuild parts before I begin a rebuild.
Since I do not know how to disassemble my unit further, and my old diaphragm is in very good shape, I think I'll return AR's diaphragm (like you said, expensive!).
If I HAD to, I think I'd drill out the rivet, tap the brass shaft, and thread in a small pan head screw to hold it all together again,....
My Weber is stamped 28/32 ADHA 4/179 8M,...looks great now!
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Just thought I'd see if anyone here had ever replaced this rubber before, using the old hardware.
That's how FU2-480 is sold,...so SOMEBODY has reused the hardware somehow.
If anyone knows where I can get a replacement diaphragm that INCLUDES the brass shaft (and the flat items that hold the diaphragm) please let me know. I'd like to have a source.
But what you see on the right is as disassembled as possible, and a replacement would have to look like that. A bare rubber cannot be used without a lot of work.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
The one I received from Midwest had the shaft already attached but it looks like it's no longer available from them.
I see some machine work in your future
I simply washed the old one nicely, dryed it, and reinstalled it. It is in very good condition, so I'll not mess with things!
I'll make a note in my Shop Manual that I'll need to drill, tap, and replace the tiny rivet with a screw when I have to replace this rubber diaphragm,...
I'll have to return FU2-480,...
Couldn't find an appropriate size/thickness of O ring for the idle cutoff solenoid in my replacement kit, but I found a beauty in my O ring stash!
Done with the upper carb,...disassembling lower right now.
BTW, I was never able to remove the main jet. It appears to consist of a ball bearing trapped in a brass housing. The ball has a
light spring behind it, so I just tested it's motion after cleaning/drying, and left it.
Man I sure LOVE/HATE carb cleaner!
Thanks, PaulC!
Thanks, PaulC!
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
- Your car is a: 1985 pininfarina spider
Cool! That's the item,...
It's pretty obvious why the metal hardware cannot be easily re-used,...
When I need a new diaphragm, at least I'll know where to find a thread with the parts source! And I also bookmarked spiderroadster.com,...
Thanks, 85redpini!
Todd.
Thanks, 85redpini!
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
