Howto Set Cam/Crankshaft without a Timing Belt installed
lugbutz
Your car is a: 1980 Fiat Spider
Post by lugbutz »
Hi
So I have a 1980 Spider 2000 FI. Currently the camshafts and crankcase pulleys timing markers are not aligned properly. The intake and exhaust camshafts timing markers are roughly 180 degrees off when the crankcase timing marker for piston no 4 is at TDC.
In the Clymer manual it states "never rotate the camshafts without also rotating the the crankshaft" It says serious damage can result.
I've read a bit about this and it seems that inorder to set the timing properly with the timing belt removed I simply need to put the car into 1st. gear, set emergency brake, then manually set the timing for the intake/exhaust camshafts. Is it as simple as that? Or am I missing something?
Exhaust Cam
https://drive.google.com/open?id=1J_HFk ... xLbDmv8Kzm
Intake Cam
https://drive.google.com/open?id=1qP9cE ... LzVIyjR9vt
Crankshaft
https://drive.google.com/open?id=1vVbiw ... N0122NH1Q7
kilrwail
Re: Howto Set Cam/Crankshaft without a Timing Belt installed
Post by kilrwail »
Why would you want to set the timing with the belt removed? It's called a timing belt because its installation is critical to achieve correct timing to allow the engine to run. You could damage a valve by turning the camshafts without a belt properly installed.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
redcars
Post by redcars »
If your engine is the 2000 and stock, then you have a non interference value train. Put the crank shaft at top dead center on # 4. Take off the timing belt . Turn the camshafts till they line up and put the timing belt back on. Check the timing of your idler shaft and replace the timing belt and tensioner if needed.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
bobplyler
Post by bobplyler »
Actually, the engine is at TDC when the camshaft is at 0 degrees AND when the camshaft is at 180 degrees. The camshafts rotate at half the speed of the crankshaft.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Nut124
Post by Nut124 »
redcars wrote:If your engine is the 2000 and stock, then you have a non interference value train. Put the crank shaft at top dead center on # 4. Take off the timing belt . Turn the camshafts till they line up and put the timing belt back on. Check the timing of your idler shaft and replace the timing belt and tensioner if needed.
Even if the valves did not hit the piston, they can hit another valve.
I would remove cam box covers and watch the lobes when turning the cams. You do not want both the intake and ex valve on any cylinder down at the same time.
aj81spider
Post by aj81spider »
+1 on the valves. I know the 1980 is a non-interference engine, but just to be safe you might also want to move the crankshaft to pull piston 4 back from top dead center a little. Then adjust the cam shafts. That way you make sure you won't bang a valve on the piston that is at TDC. After the cams are aligned properly you can rotate the crankshaft back to TDC. You should also get a 38 mm socket so you can rotate the crankshaft without having to move the car back and forth. Amazon has short ones that (at least on my car) don't force me to remove the radiator.
A.J.
2006 Corvette
lugbutz
Post by lugbutz »
That makes complete sense.... So without the timing belt
re: 38 mm... currently have one
1. Align cams properly with crankshaft just off TDC,
2. With cams aligned, align crankshaft
3. Install timing belt
4. Grab a beer!
Thank you all.... This was most helpful. I report back once Ive completed replacing the timing belt and tested
j
Jon124
Post by Jon124 »
In the pictures the timing belt is on. Just turn the crankshaft 1 rotation and the cams will line up because they rotate at 1/2 crankshaft speed.
1974 Honda CB350F
