Radiator Fan Switch
lugbutz
Your car is a: 1980 Fiat Spider
Radiator Fan Switch
Post by lugbutz »
Hi all
Quick question...Do I need to drain the rad/cooling system to remove the Radiator fan switch?
wetminkey
Re: Radiator Fan Switch
Post by wetminkey »
I did not.
Left everything hooked up tight and the resulting vacuum helped keep most of the coolant in the system. Swapping the two sensors only takes a moment, and when I was done, I bled the system as usual,...worked perfectly.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
