Cali smog kit removal
BS9ider
Your car is a: 1978 Spider
Post by BS9ider »
Hi All,
Is there a technique to removing the air injection rail? The space is very tight and I'm struggling to get a spanner on the nuts without it slipping due to the angle.
Many thanks,
Stu
Odoyle
Your car is a: 1983 Pinafarina Spider
Re: Cali smog kit removal
Post by Odoyle »
Only way I was able to get the injection rail off in my 77 was by removing one of the cam towers :|
BS9ider
Post by BS9ider »
Thanks Odoyle, that's not good news. :(
BS9ider
Post by BS9ider »
Success! I cut the pipe of with a Dremel which enabled getting a socket over the nut to remove.
CA124
Your car is a: 1969 Fiat 124 Sport Coupe
Post by CA124 »
Related to this topic - what are you all using to plug the holes? Looks like an M12/1.25pitch bolt?
Would love to hear the options.
Thanks!
aj81spider
Post by aj81spider »
Autoricambi has a set of plugs you can buy. They're a little pricey, but look much better than random bolts.
A.J.
2006 Corvette
CA124
Post by CA124 »
Thanks! I see them now. I've also located some bolts that will work but need some cutting:
https://www.mcmaster.com/catalog/124/3224
BS9ider
Post by BS9ider »
Yep, I fitted the hex plugs which I purchased from Vicks.
