Exhaust Cam Box Tower oil leak
70spider
Post by 70spider »
I just recently completed my rebuild and have taken him out for a couple of drives. At first I had to deal with an electric issue and solved it, for now, but developed a recurring exhaust cam box tower oil leak. The leak starts around the first stud by the exhaust manifold. It definitely is caused by a lack of the cam box tower sealing and not the exhaust manifold stud. I experienced this before when I replaced the exhaust cam and never found a solution before the head gasket gave out. Could the cam box tower be warped? I used the best gasket possible (AutoRicambi) and cleaned the heck out of the mating surface before assembling. I did the same procedure on the intake side with great results. Should I drive it a bit and see if it seals or just replace it with another exhaust box cam tower, lots of work :( .
2002 Mazda Protege5
2013 Buddy 170i
DRUMMOND
Re: Exhaust Cam Box Tower oil leak
Post by DRUMMOND »
Did you retorque your bolts after a few engine usage cycles? Worth a shot :)
I guess if that doesn't work then you need to check for warpage
70spider
Post by 70spider »
I did re-torque, but all was good nothing loosened. I have replaced the tower before while the motor was in the car, a serious pita. I have a newer cam box tower with the distributor opening so I will have to make a block off plate. I will drive him around for short runs just to get the rings to fully seal before I dig into him again. Thanks.
2002 Mazda Protege5
2013 Buddy 170i
kilrwail
Post by kilrwail »
Check the oil filler gasket - they are prone to leaking when they're old and brittle. It looks like a cam box gasket leak. If your cam box is really leaking, you can try to flatten any warpage by taping a piece of coarse sandpaper (i.e. 80 grit), to a sheet of glass and sliding the cover over it many times. Check it often with a good straight edge as you go.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
70spider
Post by 70spider »
The oil filler gasket is new with no leak there, also I had a cam seal leak before but there is no oil on the cam gear this time. So it looks like a chore ahead of me. I have a really good condition cam box tower from a 1608. I didn't use it originally as to keep the 1438 stock look, without the distributor provision. It looks like my vanity has bit me in the :oops: again. Well I'll tackle the the job next week end, waiting on a new gasket. Thanks.
2002 Mazda Protege5
2013 Buddy 170i
blazingspider
Your car is a: 1977 fiat spider
Post by blazingspider »
I have a few 1438 exhaust cam boxes. PM me if you're interested in getting one.
