I have looked at a couple older posts.
I have just gone through this: after the rebuild, had a small leak at what looked like the 2nd stud from the front of the motor. Pulled it out (wasn't that tight), used some permatex high heat thread sealer (white) and a new stud. Actually then leaked more. Now, this stud is longer going into the head. Is that an issue?
I do have the old, stock studs. any ideas? is there a better sealer?
When everything else is just great, this is a pain.
thanks,
geo
leak at exhaust stud
- geospider
- Your car is a: 1979 Fiat 2000
Re: leak at exhaust stud
I use the copper colour permatex which is great for high heat and oils . Works like a charm for me.
Hope this helps
Nick
Hope this helps
Nick
- geospider
thanks, ill look for it
