Trunk key not working!
Nicketts
Contact:
Post by Nicketts »
Hey friends,
Took the car for a nice warm-up today, then drove to dinner. Got home, and can't open the trunk. I did tighten the bolts that hold the loop that latches below, on the trunk lid today (found it loose). Can this possibly affect the lock? Put the boot cover and towel in the back seat for now. Man, this car! Any thoughts?
1982 FI Spider 2000 Grigio Fumo
15 Civic EX sedan
14 Fusion (gone)
07 Civic Coupe (gone)
82 BMW 320i (never should have traded)
73 850 Sport Spider (long ago, but a great car)
wetminkey
Re: Trunk key not working!
Post by wetminkey »
Do you mean that the key will not turn, or will turn, but does nothing?
Assuming the former, mine has always required a little light, downward pressure on the luggage rack for me to be able to turn the key,...the trunk latches tight against it's gasket. And you just tightened the mechanism,...
I don't suppose that you'd be so lucky for that to be the solution.
Best of luck with it!
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Nicketts
Contact:
Post by Nicketts »
Unfortunately, it is the latter. Key will turn, but does nothing. I'll try pushing anyway, thanks for the help!
15 Civic EX sedan
14 Fusion (gone)
If you find that you cant get in, drill a small hole, just large enough to accept an awl or small screwdriver, as shown here. Insert the awl and rock it back and forth horizontally, left and right. You should be able to catch the arm that will release the latch mechanism. Plug the hole with a rubber cap from the local hardware store and you are good to go. Hidden by the license plate anyway.
Nicketts
Contact:
Post by Nicketts »
Great solution, but kinda hope I don't have to do that. I'm in awe of your ingenuity for figuring that out. However, I still wonder what the fix is... It did work fine when I put the top down to take the car for a drive initially, cause I got the boot out then. And that was well after I had tightened the latch on the lid. I'll have to wait until after work to check it. I'm hoping, like other glitches that seem to pop up, it will fix itself.
15 Civic EX sedan
14 Fusion (gone)
I didn't come up with it, but at any rate, once you get the trunk open, the entire mechanism presents itself pretty clearly.
Nicketts
Contact:
Post by Nicketts »
Well I was lucky. A simple push on the trunk lid made it work. Just another quirk on the quirky Fiat road. Spiders Unite! Thanks friends.
15 Civic EX sedan
14 Fusion (gone)
