Im putting all the new bits and pieces back in today after changing the timing belt, water pump, alternator, tension bearing, starter, hoses, thermostat, and lots of little other things. I noticed this that i did not notice when i took it apart. I suspect it is correct since that is the only way the mounting bracket will fit, but does anyone know what logic it was to put the fan so high? a good half of the blade goes above the fins. I almost want to modify the bracket to make it fit in the center, but there must be a reason why they did it like this. Also, i noticed the fan can be made to blow air across the radiator and out the front OR suck air in thru the radiator and into the engine bay. Which way is more desirable/stock?
Thank you as always
David
