Carburetor issue
Carburetor issue
New '79 2000 owner and experiencing a stalling issue at every stop sign, it just won't idle. From what I've read, this year has the worst carb and intake. Also read that the 1800 cc intake is a nice replacement. What carb would be the easiest, best fit to replace the original. Any advice would be helpful. Thanks!
- nelsonj
- Your car is a: 1972 Spider 124
Re: Carburetor issue
I'm not sure about the 79, but my 78 had an electronic idle control valve. It went bad and it would stall if I took my foot off the gas.
Simi Valley, California
Spider 1800
Romans 10:9
- dinghyguy
- Your car is a: 1981 spider
Hi and welcome
My 79 has a single plane now and a 32adf
carb . The p.o. Did it and I think a 34 adf would have been a bit more powerful .But if that is the issue get a kia.... So if I were starting where you are i would get the 34'ad'adf
Dinghyguy
Dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
- Your car is a: 1979 Spider CS2 weber 34adf
When working properly the 79 carb etc is ok-ish.
I swapped mine out for an 1800 intake and Weber 34ADF. once jetted/tuned properly, goes GREAT. I have stock air filter and 4-2-1 exhaust
various KTMs and V8's
RR Sport
'79 Spider 2000
RR Sport
'79 Spider 2000
- geospider
Agreed on the carb and manifold replacement.
The 28/32 on the '79 is long known to be the dog of all webers on these cars.
I had a new out the box one from the PO, used it to get smogged here in Cali.
PO also gave me the 1800 single plane manifold and a 32/36.
since I had to do a lot of engine work; swapped them out. get them dialed in and they are great.
the 34's and 38's that some have done will give you a bit more since primaries are bigger and sinc'd vs progressive. but the 32/36 is pretty easy to manage: as with all of these: float adjustment and jetting.
this gives you a good idea of the difference between the manifolds; crazy.
AR has a kit for all of this as well as options for each piece. check e bay for the carbs: a bunch out there
Geo
Geo
- Nanonevol
Beware the Chinese copies that are sold. I know the price is tempting and some have good luck with them but I'd first look around for the genuine Weber.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- geospider
+1 on genuine Weber
