Cam timing marks
Re: Cam timing marks
just a little more info: if you upgrade a 2L engine to the large valve head, it turns it into an interference engine.
Thank you for those tips.
The manual does talk about slacking, but not in that much detail. Thats a big help.
- phaetn
- Your car is a: 1974 Fiat Spider 1800
No problem.
I forgot to add, of course, that after turning it over by hand to make sure everything is still lined up. That's when you can tell if something slipped or not.
I had an annoying issue last year when the exhaust cam would always be off by one tooth after I cranked it by hand: everything else was good, but that kept going off. Must have had to do with slack. I kept at it and kept at it, but boy it was frustrating.
More recently I have installed adjustable cam pulleys. The exhaust one slipped in its positioning about a month ago and the engine just lost pull after 4,000 rpm. It was fine up to that point, but then wasn't breathing right and I could feel it wasn't happy. These engines are best between 3,000-5,000 rpm and I could tell it wasn't in its sweet spot. Readjust the synchronization, problem solved.
Cheers,
phaetn
Cheers,
phaetn
First, thank you all for your help.phaetn wrote:No problem.
Cheers,
phaetn
Here it is on. Before i clean everything and button it up, i wanted to make sure this looks right. I don't remember the belt riding on both sides of the aux shaft, but i did turn it 3 full revolutions tdc on the cam marks and everything feels good.
So, is that the way it should be? I don't see any other option, but i just wanted to check.
Thank you as always
If your crank mark is on 0 yes you are good.
- phaetn
Confirmed.
I thought it was maybe odd that the belt was on both sides of the aux shaft pulley, too. I went out and just checked mine. Hard to see behind the timing belt cover that I have on, but my belt is like that up against the flange on the passenger side of the pulley, too.
I guess I am so used to looking at it from the driver's side that a front aspect threw me.
All the best when you go to start it!
Cheers,
phaetn
Cheers,
phaetn
