Cromodora wheel caps
I'm looking for 4 center caps for Cromodora wheels. I believe they are CD-3's. The wheels look identical to the 1st wheel on the C.Obert & Co. "wall of wheels". (http://www.fiatplus.com/images/P/CD3.jpg) It states they are called the Fergat wheel and use cap #4150453. The cap should measure about 6 inches across. Any help would be greatly appreciated. Thanks. -Tim Keras
- stefhahn
Re: Cromodora wheel caps
Hi-
if they are CD-3s then you will find a mark "CROMODORA"and "5x13" on the outer side and a "CD-3" on the inner side of the wheel. They are remakable light, as they are magnesium wheels. Watch out if you plan to sand them, this is no easy task as they should not be sanded with the same stuff as alloy wheels!!!!
The caps are quite rare - http://www.ebay.it is a fairly good source, I have seen them offered there twice this year (sic!) - but nowhere else so far.
In addition I'd check with vendors in the US who stock used parts (So Cal Mark from here, Bruces, FiatPlus, ...) i.e. place an ad in the "parts searched" section here in the forum. Good luck!
ciao,
Stefan
ciao,
Stefan
- perthling
Actually, the Fergat design is slightly different; the two 'ribs' which separate each of the slots come towards each other as they extend from the centre. AFAIK, they take the same centre cap though. (I'll check once I get my other Coupe into my new shed). Fergats are magnesium too - and probably even more rare than the CD3s.
_______________________
Perthling
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
http://www.fiatlancia.org.au
Perthling
Thanks for the info, but can anyone supply a photo so I'll know what they look like if I should be lucky enough to locate them?
- perthling
The caps should look like this:
http://gallery.italiancarclub.com/124og ... G_3472.jpg
Sorry I don't have a closer photo available at present.
Perthling
Perthling
i had a set uf wheels like that. if i recall correctly c obert made repros of these
Here's a pic of mine:
yup, thats what i had before i bought my nos campanolas
what is the diameter of that cap? I just got a selection of parts and there are some caps like that
- stefhahn
I noted down that the CD-3 wheelcaps have an inner diameter of 143mm, outer diameter of 154mm
ciao,
Stefan
ciao,
Stefan
- stefhahn
Hi -
I heard rumours before but now I'm sure - you can get these hubcaps new now from italy: http://cgi.ebay.de/4-COPPE-RUOTA-FIAT-1 ... 240%3A1318
ciao,
Stefan
ciao,
Stefan
Thanks Stefan. I should have known that once I bought a used set of these somebody would locate a new set! Just my luck, as usual. -Tim
